Race rods for A15
From Singapore
Anyone can recommend good quality H pattern forged rods for a race A15? TIA.
Posted on: 2009/8/14 14:40
Race rods for A15
From Freo
give THESE an Optic..
Posted on: 2009/8/14 15:27
A15 PSI Project Motor
'72 CB750k,
Re: Race rods for A15
From newcastle, NSW
Check this out maybe of some use to you.
Are those Bproject rods mike?
How much?
Posted on: 2009/8/14 15:41
From Cape Town South Africa
Those look like eagle rod ?
Posted on: 2009/8/14 15:50
Racing started the day the 2nd car was built!
From Perth
CA18 spool rods
They are 560g each with ARP bolts installed
$550 from spool
20mm pin though... so chose pistons wisely or get them bronze bushed
Posted on: 2009/8/14 16:35
From sydney
CA18 con rods on an A14? now i've heard everything! is that $550 each or for a set? where do you get tham from?
Posted on: 2009/8/14 16:43
From Singapore
Those Bproject rods look like the set to have. How do they compare to Carillo rods and how much? Are those ARP bolts? Can pay via credit card? Pls PM me details. Thanks.
The A15 engine I'm building has 79 forged high compression pistons, 320 degree Nismo camshaft, forged steel 2.9kg flywheel. What sort of bhp/ torque figures are realistically achievable from this motor?
Need some info on increasing valve sizes.. will start a new thread.
Posted on: 2009/8/15 2:43
aftermarket forged I beams are lighter rods than H beams for same strength.
Posted on: 2009/8/15 4:32
From Perth
Posted on: 2009/8/15 5:32
From Christchurch NZ
I've done a bit of research. And I found that ca16de rods are bigger and stronger than the a series rods, but lighter that the ca18de rods. I'm yet to weigh a ca18det rod, but I think they are the same as the de rods.
I got a set of ca16 rods for nix. Plus the ca16 rods have a 9mm rod bolt, so thats stronger right out from the getgo.
Posted on: 2009/8/15 6:55
Forced Induction!
(1) 2 3 »
