Does anybody have silicon moulds (poured into the port, then removed once set) or cross section pics of a gx head (I have seen cross sections for other heads, but not any a12 gx heads - likely because nobody in their right mind would cut one into sections for such a purpose. Anyhoo - I'm wondering how the gx heads are shaped in the bowl area, down to the valve seat. I'm curious as to whether or not that point would still represent the biggest restriction to flow, and therefore the power potential of either the gx or a14/15 (all else being as equal as practical) in std form not being markedly different.
On how far to machine the deck of any head to bump up the compression ratio, there's enough variance in the heads in question (possibly chamber shape, but more importantly the possibility they have been previously machined) - look realistically there is no safe way to guess, and it really warrants checking hte capacity of each cylinder (might have been rebuilt and bored to the next oversize, which means slightly more capacity, so higher compression) and measuring any piston dish, and then of course measuring the volume of the chambers. Then doing the math to calculate the actual static compression ratio.
As an example (that I have used before) on minis, there's a certain model hepolite piston for the 1275 a-series which lists it's nominal compression ratio as 9.75:! - for the 40 thou oversize pistons, and a std head capacity, they actually measure out to be over 11:1.m There's just no way to know without measuring, thankfully the measuring and the mathematics isn't too hard.
Now once you have the current compression ratio, you can start with the harder maths (that can be done with some free software btw) - you see you have to consider other things.
In general all else being equal an alloy headed engine will tolerate more compression than one with a cast iron head.
A head with decent quench areas will safely run more comp than a fully open chambered head. excessive carbon deposits can form hot spots, or worn valve guides can let oil into the cylinder which contaminates the intake charge either of which will invite the onset of detonation much sooner.
small tangent - most of hte distributors are over 30 years old now, so the springs on the mechanical advance mechanism may have sagged a little, which means the mechanical advance comes in too soon - which possibly shows up with the symptom of the motor starting and idling well, but pinging (significantly) from just off idle (with throttle open a fair bit) to about 3500-4000rpm, and it running smooth as silk above 3500-4000
I've added those last two in because they are scenarios that can occur and deceive the owner that they have to run less compression than they currently have on the old motor, because it's pinging badly already.
To a lesser extent, bore size has an effect - generally the smaller the bore, the tighter the ball of air/fuel is squeezed just before the spark/burn cycle, so it's less likely to have trail ends detonating. Or in other words smaller bore, safer from detonation. This won't matter much across the range of a series blocks, but it does mean that (if it had identical chambers etc) an a12 engine would safely run more comp than something like a big v8 with a 4+ inch bore.
And one last major factor - namely 'dynamic compression ratio'. At lower rpm, the gases don't start to get compressed (since they'll be shunted back up the intake to some extent) until the point where the intake valve closes, and the piston is already well on its way up the bore. Meaning that if we closed the valve at exactly bottom dead centre, it'd achieve a running/effective/whatever compression ratio more or less equal to the static comp ratio. but if the intake doesn't close till say, 30 degrees after BDC, it will push some intake back up and out, and now have a smaller amount of air/fuel to compress, and it'll act like a much smaller capacity squeezing the gases into teh same chamber.
So dynamic compression is a comp ratio worked out with cam timing figures plotted in there, and gives a clearer picture of what is really happening at lower rpms and what comp ratrio you see. So from that it is probably clear that the bigger/longer duration cam you run, the more compression you can safely run . What in fact happens is with wilder cams, you actually 'need' more compression to get the engine to work efficiently at higher rpms.
Now that doesn't mean you run some outrageous drag race only cam profile, of course not, but it does mean, after taking into account the other factors you have to then really match up the cam timing and compression ratio to one another.
VEry basically with a stock cam, the gains in output from compression ratio increases aren't massive (at least within the scope of what is available going from low octane unleaded to 95ron) - so I'd suggest not going far past 9.5:1. You'd probably get away with 10:1 as long as the valve guides are good, timing is spot on, and it's a closed chamber head. As you advance into bigger cams, something still streetable, but far more 'oomph' up top - something perhaps around 260-270 adv duration - you'd be looking at 10-10.5:1 I'd well suspect you could go to 11:1 on 98Ron and that sort of cam, but that's speculation (and experience on other similar engines) but the gains wouldn't likely warrant it over the 10-10.5:1 . If you were massively motivated, you could hypothetically run as much as 12:1 or more on a stock cam and pump fuel, but supplement with water injection to keep it safe during the times you feed in more than about 60% throttle. Of course that is more work, and some up front cost, and you'd need to be certain to refill the water reservoir, because if it ran dry, and you ran wide open throttle you'd toast the engine pretty quickly.
Posted on: 2009/8/15 1:45
