#1 Race rods for A15
dworks Posted on: 2009/8/14 14:40
Anyone can recommend good quality H pattern forged rods for a race A15? TIA.
#2 Race rods for A15
Dundee1000 Posted on: 2009/8/14 15:27
give THESE an Optic..
#3 Re: Race rods for A15
steveo Posted on: 2009/8/14 15:41
Check this out maybe of some use to you.
Are those Bproject rods mike?
How much?
#4 Re: Race rods for A15
superbin Posted on: 2009/8/14 15:50
Those look like eagle rod ?
#5 Re: Race rods for A15
dattoman_1000 Posted on: 2009/8/14 16:35
CA18 spool rods
They are 560g each with ARP bolts installed
$550 from spool
20mm pin though... so chose pistons wisely or get them bronze bushed
#6 Re: Race rods for A15
ratsun_a14 Posted on: 2009/8/14 16:43
CA18 con rods on an A14? now i've heard everything! is that $550 each or for a set? where do you get tham from?
#7 Re: Race rods for A15
dworks Posted on: 2009/8/15 2:43
Those Bproject rods look like the set to have. How do they compare to Carillo rods and how much? Are those ARP bolts? Can pay via credit card? Pls PM me details. Thanks.
The A15 engine I'm building has 79 forged high compression pistons, 320 degree Nismo camshaft, forged steel 2.9kg flywheel. What sort of bhp/ torque figures are realistically achievable from this motor?
Need some info on increasing valve sizes.. will start a new thread.
#8 Re: Race rods for A15
D Posted on: 2009/8/15 4:32
aftermarket forged I beams are lighter rods than H beams for same strength.
#9 Re: Race rods for A15
dattoman_1000 Posted on: 2009/8/15 5:32
#10 Re: Race rods for A15
A14force Posted on: 2009/8/15 6:55
I've done a bit of research. And I found that ca16de rods are bigger and stronger than the a series rods, but lighter that the ca18de rods. I'm yet to weigh a ca18det rod, but I think they are the same as the de rods.
I got a set of ca16 rods for nix. Plus the ca16 rods have a 9mm rod bolt, so thats stronger right out from the getgo.
(1) 2 3 »
