#1 Help Identifying camshaft
BRUTE Posted on: 2009/8/18 2:47
Just picked up a couple of engine components from ebay and have a cam that is definitely A series, but has the markings O or maybe C (very hard to tell) and 740 on the end, no other identifying markings. Can anyone assist?
#2 Re: Help Identifying camshaft
b310gx Posted on: 2009/8/19 2:01
Could you give us some background on the engine. That could be 74 degrees, so it might be a factory 74 degree grind. Other than that, try looking at Crow cams, Wade cams, Tighe cams for their A series grinds. maybe a part number will jump out at you.
#3 Re: Help Identifying camshaft
BRUTE Posted on: 2010/1/7 6:34
Cheers for that, the engine came to me in pieces from a datto nut. I'll get some pics up asap. Whats a 74 degree cam,ie stage 2??
#4 Re: Help Identifying camshaft
ddgonzal Posted on: 2010/1/7 6:55
Cams are not easy to identify. Often you have to assemble the engine, then use a dial guage and timing wheel and map it out.
Hopefully the O740/C740 will mean something to somebody.
#5 Re: Help Identifying camshaft
woody Posted on: 2010/1/11 9:49
its definatly not a camtech number sam, i stripped my a 15 down last week and its got 1366 on the end. on both of my camtech cams is the grind number followed by the intake lift. ie 640-106 for my 186 holden, ill have a look at malcoms (camtech) book tomorrow and see if 74 means anything in the lift department
