« 1 ... 13 14 15 (16) 17 18 19 ... 22 »
Re: 1k wags PV a15 t50 aka msdrift
From perth airport
no word yet they looked busy , maybe tomorro
had a xy gt race race on the dyno when i got there and a vk speedway car waiting to go on the dyno so yer hopfully hear from them soon
Posted on: 2009/8/17 10:34
perth airport parking
Datsun 1200 ute A14
From perth airport
she's back and goes a lot better , need'd cooler plugs and more timing and the floats where out, plus worn out linkages where giving uneven throttle so yer its a lil goer now but only revs to 6800 and hits a wall ? so not shore why ? but maybe it doesnt make any more power after 6500 so ill just live with that .
bummer no hp read out :( the dyno is old and doesnt give hp
Posted on: 2009/8/18 6:40
Datsun 1200 ute A14
From Freo
Six eight... .. pft...
the bunky 12 sees eight... :D
Posted on: 2009/8/18 7:07
A15 PSI Project Motor
'72 CB750k,
From Perth WA
maybe its got a potato up the exhaust
Posted on: 2009/8/18 7:33
datsun 1000, Its not the size its how u use it.
From perth airport
yer it pulls hard then 6800 barp barp barp allmost like a rev limiter in a sr20det
could it be the mal elecy dizzy maxing out ?
andy said the motor would go to 8500 no worries when he had it
Posted on: 2009/8/18 7:57
Datsun 1200 ute A14
From Perth WA AUS
Need more / better fuel delivery I think.
Posted on: 2009/8/18 8:54
Datsun 1200 2Dr sedan.
From Perth WA AUS
You havn't done another dodgy tail pipe muffler mod have you?
Posted on: 2009/8/18 8:56
From Freo
yea I modded the Dizzy b4 u got it so the Bunky 12 would out rev ya.. ha ha
bring on the 8k... ha ha
Posted on: 2009/8/18 9:20
'72 CB750k,
Jordy,
So this is Andy's old engine? This thing has a pretty tough reputation.
From what you are saying I reckon it is the dizzy, unless tappets need some fine tuning? but that wouldn't yield many more rpms if they are already quite close to what they should be.
Or maybe the valves need to be seated again? Quick grit n lap?
Mals dizzies are great, got one running on my A10 but I wouldn't put it on my screamer A12 though. Here is the monster dizzie I have on the A12.......10mm leads.
Then again I dunno, those (Mals) dizzies are reasonable well made so they should hold out to at least 7500.
Can you borrow someone elses performance dizzie to see if it works any better??
Posted on: 2009/8/18 9:36
From perth airport
i drove it then home from work and i was reading the taco wrong its braking down/hitting a wall at 5500rpm
yes this is andys old motor ,
im gonna ring the dyno tuner tomorro and see wat he thinks
but the only change's are new elec dizzy
rebuilt andys webbers
new fuel pressure reg
new spark plugs has dyno tuner recomended
and new 2.5 inch zorst
has new leads but i think i might buy/borrow a set to check
i run bp ultimt 98 fuel
thinking of getting some racing fuel from a speedway racer down the road to see if it helps
yer im all ears on ideas has im pretty much guessing but ill get there
Posted on: 2009/8/18 11:49
Datsun 1200 ute A14
