« 1 2 (3) 4 5 »
Re: engine in but just more problems :(
From northern 'burbs adelaide
ok so the only thing left is oil pressure ... can someone with experience wit this please contact me as im all out of ideas
Posted on: 2009/8/26 11:42
From newcastle, NSW
Mmmmmmm........................ very interesting!!
Have you checked out the oil pump itself? could be the relief valve? or the spring in front of it?
Pump itself might be worn out?
It could be somthing as simple as an air leak in the oil system?
Just throwing some ideas at ya,is there any pressure at all?
Posted on: 2009/8/26 12:08
no pressure at all and its a brand new pump
Posted on: 2009/8/26 12:13
What are the chances of pulling the engine out again?
I'd be checking the simple things like oil pickup etc an following the oiling system around.
Did you put it together yourself (I can't remember if you did, or if you did some of the machining)?
Posted on: 2009/8/26 12:18
yea i put it together myself and its only the pickup that goes on before the pump and i put that in with the little gasket supplied and it was all torqued up ... and theres no way in hell im pulling the motor out again, just ask andy
Posted on: 2009/8/26 12:21
Unless there is something up with the regulator valve in the actual pump, it can only be a few things.
So when you crank it, the gauge reads nothing.
Has it got the right oil filter?
Try another pump or use that pump on a working A-series.
Check the pressure gauge works?
Posted on: 2009/8/26 12:26
Sorry oil filter wouldn't make sense as you'd still see pressure.
Posted on: 2009/8/26 12:28
i know the pressure gauge works coz i worked before i changed the motor ... i also have the idiot light still attached and that stays on as well
Posted on: 2009/8/26 12:33
From sydney australia
I've had something similar happen & it was the gasket between the oil pickup & the block. It had fallen off one of the bolts when I was doing it up & was blocking the gallery up into the block. Maybe the same thing has happened to you. The bad news is that I had to take the motor out to check & repair. The cause of my mistake was I had a baffled sump & I had to put the pickup through it before fitting either to the block.Maybe you could remove the oil pump & drop the sump, then get a mirror on a stick likes dentists use to inspect the pick up gasket. I suggest this because your obviously not getting oil from the sump.
Posted on: 2009/8/27 2:23
ok so i finally have pressure up, filled the pump with vasaline and now shes away
Posted on: 2009/8/27 8:37
« 1 2 (3) 4 5 »
