Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up.
From Armidale N.S.W
Thanks Heaps Fellas. Yeah TRX box is definitely longer going to make some measurements as im sure the mounts (cross member) are in the same place.So will check that and if shifter is going to be much further back. May just look for another stanza 4 or 5 speed box.
Posted on: 2009/8/30 1:24
73 1200 wagon SOLD
Subject Poster Date
     Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 7:39
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/29 8:25
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 8:28
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. steveo 2009/8/29 8:36
           Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/29 8:38
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 8:41
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. lethal_john 2009/8/29 9:01
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 9:09
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/29 9:18
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 9:23
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. revhead001 2009/8/29 10:22
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 10:28
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. revhead001 2009/8/29 11:42
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. Anonymous 2009/8/29 12:11
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 17:12
           Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. tommo73 2009/8/29 17:35
             Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. heathbruce 2009/8/30 0:29
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. superbin 2009/8/29 15:53
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/30 1:24
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. ddgonzal 2009/8/30 1:46
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/30 4:24
