Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up.
Stanza gearbox is probably 26.3 inches in length (same as automatic transmission length). This is the 'stumpy'. Most other 63-series are longer.
Posted on: 2009/8/30 1:46
Subject Poster Date
     Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 7:39
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/29 8:25
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 8:28
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. steveo 2009/8/29 8:36
           Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/29 8:38
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 8:41
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. lethal_john 2009/8/29 9:01
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 9:09
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/29 9:18
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 9:23
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. revhead001 2009/8/29 10:22
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 10:28
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. revhead001 2009/8/29 11:42
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. Anonymous 2009/8/29 12:11
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/29 17:12
           Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. tommo73 2009/8/29 17:35
             Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. heathbruce 2009/8/30 0:29
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. superbin 2009/8/29 15:53
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. DatsAndy 2009/8/30 1:24
         Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. ddgonzal 2009/8/30 1:46
       Re: Stanza 4 speed jammed in reverse, Near To sellin Up Fed Up. PIGDOG 2009/8/30 4:24
