Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
12a 6 port rotary motor & 6 speed manual gearbox.
84ker88
Posted on: 2009/8/29 23:52
hey guys i have changed my mind with my 1200 coupe project so now im selling my 12a 6port rotary motor and 6 speed rx8 gearbox, i have never had the motor going so i dont know the condition, was told when i brought it (2 months ago) that it was running and didnt blow smoke but cant confirm this, it has intake manifold,carby, distributor...missing flywheels and counterweight!
the 6 speed has only done 3000kms since new and comes with slave cylinder and hose, and starter motor and gearknob! this gearbox will bolt to any series rotary motor! motor- $650 gearbox-1800 will do a deal if they go together! will swap for ca18det and parts! thanks, justin. Attach file: P1010075.jpg (34.68 KB)![]() P1010079.JPG (34.73 KB)![]() P1010086.jpg (24.69 KB)![]() P1010091.jpg (36.81 KB)![]()
#2
Re: 12a 6 port rotary motor & 6 speed manual gearbox.
STITCHMASTER
Posted on: 2009/8/30 15:15
hi just want to know do you have the crossmember and gearbox mounts also what trans tunnel mods are needed to fit this in 1200 thanks
#3
84ker88
Posted on: 2009/8/31 8:47
hey mate, no there are no engine or gearbox mounts! i hadnt made any yet, the motor was just sitting under the car on a stand that i made up! wouldnt be hard to make mounts! you will have to cut the center out of the original crossmember to allow the motor to sit low enough, i have a template crossmember made out of cardboard (to exact measurments) that will do the job, i have showed a engineer this crossmember and he said it was fine! trans tunnel will have to be cut out and enlarged! thanks, justin.
#4
Matto1kUte
Posted on: 2009/8/31 9:31
not sure but i thought maddat did a rotor to 1200 conversion kit. if not buy a cheap mig and make it ya self :)
#5
84ker88
Posted on: 2009/8/31 10:10
nah maddat dont do one yet, i think there still working on it! it wouldnt be hard at all, the engine mount is hust a bit of flat plate that bolts to the front of the motor!
#6
84ker88
Posted on: 2009/9/2 10:25
PRICE DROP!!!
motor-$500 firm gearbox-$1500 firm need this stuff gone! You can view topic.
