« 1 2 (3) 4 »
Re: Datsun ID plates - What do you want?
I have never heard of it being illegal. It's only if you try to pass it off as genuine would there be a problem.
On the other hand, I've always heard that re-stamping the engine number or body/frame number is illegal.
Posted on: 2009/8/29 6:00
If it were intended to replace one for restoration purposes then it should not be a problem. However if it were used so that someone would try to get it past registration purposes then it would be a problem for the individual who tries it. Police confiscated a car of mine years ago because they 'suspected' it had a stolen engine. The block of my old 308 was milled and the engine number came off so I re stamped it. Although it was not illegal it was suspect. The cop shop was around the corner and they were called while I was waiting at the counter and I lost the car for almost 6 months. Even then the heads were off and I had to get it towed and paint was damaged.
Posted on: 2009/8/29 7:28
From Christchurch NZ
thats reminds me of a funny story. A mate of my old mans was telling me a cop who thought he was very knowledgable wanted to check the engine number on a holden that he'd pulled over. He got the owner to open the bonnet, and wrote down the number off the engine. Funny thing is, (And those of you who know holden motors will be familair with where this is located on holden motors) he wrote down the firing order!
Posted on: 2009/8/29 21:54
Forced Induction!
Thanks for the replies. As stated these aren't a compliance plate so there is no legalities involved.
Unlikely this plate alone would convince an RTA official your car came out with a different motor as they go off documents they have in their system not what you tell them.
Also I didnt sell any on ebay, but I did see the ones mentioned but they weren't an exact replica with size or fonts etc, these ones will be alot better.
Also no probs with getting a standard spec one, they will be catered for as well.
As I said, will probably be a minimum of 6 weeks at least til I have them in my hands, but they are definitely coming.
cheers
Posted on: 2009/8/30 22:52
From Freo
I'd be in for some B10 ones... :)
Posted on: 2009/8/31 1:56
A15 PSI Project Motor
'72 CB750k,
Just got back from OS, so getting straight into these.
For engine and chassis numbers, you would need to stamp these yourself which is how they were done at the factory, not a hassle though.
While I'm here, can someone confirm for me that a 1200 ute model number is b120?
cheers
Posted on: 2009/9/14 2:16
From northern 'burbs adelaide
my ute is a B120 and is a early model so i would say yes but dont hold me to that
Posted on: 2009/9/14 2:25
ID BE UP FOR ONE
Posted on: 2009/9/14 10:27
Car free
As long as it is simply the manufacturers ID plate [not an ADR compliance plate] then the law doesn't give a rats a*s*. The only thing that will be desirable is that the chassis number on the plate matches the one on the body.
If the engine number on the plate matches the engine in the car, then all the better but if an original car has had a standard [or otherwise] engine replacement, then these numbers won't match any more.
In the end, these plates are more for cosmetics these days then much else.
I would really like to get one for a KB10, so if this is possible then I would dearly like to hear from you via e-mail as I do not get on here very often.
Posted on: 2009/11/9 13:40
Love your Datsun.
Treat it well.
From Sydney
I up for 2 B110 id plates, as both the plates on my cars are looking rather tatty these days...
Posted on: 2009/11/9 21:34
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
« 1 2 (3) 4 »
