« 1 ... 3 4 5 (6)
Re: Weekend car stuff, what did you do?
From sydney nsw
woke up the neighbourhood with a couple hot laps at 10pm in the race car!
Posted on: 2009/8/30 20:54
From pooraka,,adelaide
mine wasnt as good as that but i scouted both u-pull its and replaced alternator in the 620
Posted on: 2009/8/30 21:40
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Albuquerque NM, USA
Installed engine and trans....oh, wait that was last weekend.
didn't do poop this weekend
Posted on: 2009/8/31 3:00
From Brisbane
I had a bit of a bummer of a saturday... Drove the ute out to willowbank for the fast fours and rotorys Jaamboree all ready to race, my first ever quarter mile pass at a 13.18 at 108MPH
Lined up for the second pass later on in the day, and was going to give it a whole lot more this time in the burn out and in the take off. Started the burn out and just got her into 2nd gear and bang! At first i thought i blew a tyre but i then saw my whole passenger side rear wheel bouncing away behing me through the revision mirror.... mmmm DAMN now have too replace a few wheel studs and nuts.
Ended up getting a lift home and got the work ute out and hired a trailor and trailored the ute home
Posted on: 2009/8/31 3:27
If you want more inches, stroke it
From South Africa
Fitted and painted the cage and started with the body work, fun fun
jpg  Cage paint (Medium).JPG (47.36 KB)
9082_4a9b47f52e36b.jpg 450X600 px
Posted on: 2009/8/31 4:48
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From Cape Town South Africa
Nice one rezlo! Are you aloud to do that in your class? With the fine class here in cpt we can fit a roll bar but no cage and we cant remove the back seats.
Posted on: 2009/8/31 7:54
Racing started the day the 2nd car was built!
From South Africa
I am having rear "seats" made to fit, whole interiour is going charcoal and black, front seats will be leather,
Its the ture FIA homoligated cage/roll over as required to run true "Marque" in the international Springbok series coming up in November. Its seen as a roll over system now, but then it was known as a cage, its still a 4 point so you could use it in Fine if you got the rear seats to fit, in my case im just doing it out of 1" high density foam.
Posted on: 2009/8/31 8:42
'07 Hilux - Tow car
Now that i would love to copy please
Posted on: 2009/8/31 18:08
From Cape Town, South Africa
Build my Coil Overs and strut brace and fitted it all together with the camber / caster plates.
Coil Overs
Camber / Caster Plates
Posted on: 2009/9/1 9:39
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
From sydney australia
I replaced the centre bearing in the tailshaft of my D21 Navara, she was a bit wobbly. Put it all back to find that the front uni joint had broken, so I replaced this too. had to go back to the Part Store as the first ($22) uni was the wrong one. Wouldn't you know the correct uni was more expensive ($33).
Posted on: 2009/9/1 10:56
« 1 ... 3 4 5 (6)
