Re: Temp. reaches 3/4 only driving 10 min. !!!
The temp is hot, you couldn't even open the cap until it was cooled down.
A12 engine running at the correct temperature is the same! Checking the temperature by feeling with your hand means nothing.
Best fan is the stock ones. I've seen so many electric fans overheat. That may be your problem, especially if you just fitted it.
Thermo-stat gasket is about $3 at any auto parts store.
Posted on: 2009/8/8 21:51
From Delaware, USA
Thanks will all the advise you guys have given me. That's why I love this site. You get answers to questions, you can help others and also buy or sell any part hard to find or might need to get another dead Datsun back to life. I will let you all know how everything came out when I'm done with my datsun. Cheers
Posted on: 2009/8/8 22:50
When I first got my coupe I drove it from the thansport depot in Sydney to my home which was about 85 miles to the south. It ran on the verge of overheating all the way & was saved only by the fact that it was a cold day with a strong wind blowing straight at me & into the radiator with plenty bof light to medium rain.
I replaced the water pump & all related rubber parts. A check into the radiator revealed only six or so visible tubes, four of which were completely blocked.
I was going to replace the core with a heavy duty one, but one was not available at the time & was going to take too long to make, so I settled on a stock replacement.
Thanks to the cheesecloth condom filter, I have never had a moments cause for concern ever since, neither in summer heatwave or in recent sleet conditions.
Returning the whole cooling system to essentially new, & stock condition is always a good start & a heavy duty radiator is never a waste of money, just make sure that the thermostat is of a suitable heat range & is actually installed. [& not left on the bench]
Posted on: 2009/8/9 15:34
Love your Datsun.
Treat it well.
From Delaware, USA
Does anyone have a pic of the cheese clothe condom filter?
Posted on: 2009/8/9 16:22
Posted on: 2009/8/12 7:10
From Delaware, USA
Instead of getting a 3 core radiator, they suggested to clean mine because it was a special order for the 3 core and that my radiator was in really great shape. So I got my radiator cleaned and painted. I put it on today and wala...the temp stays around 1/4 in idle for more than 30 min. and if i rev it up a little, the gauge will start going down. Now back to get my car ready for another import auto show in Atco, New Jersey. Hopefully I make it this time...
Posted on: 2009/8/15 1:30
Yes, there's absolutely no need for 3-core radiator. 2-core radiator will cool even an A14 -- if it's in good condition.
Posted on: 2009/8/15 1:36
junior wrote:
I put it on today and wala...the temp stays around 1/4 in idle for more than 30 min. and if i rev it up a little, the gauge will start going down....
Nopw it's time to fit that new thermostat so that the engine runs at the correct temperature instead of overcooling as it obviously is now.
Posted on: 2009/8/31 14:06
Love your Datsun.
Treat it well.
From Delaware, USA
That's true, and more now that it's starting to get chilly around here. I don't barely use it unless it's for shows or a really sunny weekend.
Posted on: 2009/8/31 16:20
« 1 2 (3)
