E15 dizzy cap and rotor.
From Gawler, Sth Aust
Hey peoples.
Have people with this distributor had any trouble finding rotors and/or caps. In the wiki it says the part numbers are CAP-BOSCH GM554 ROTOR-BOSCH GM555. Is this right? The writer seems to be unsure.
Cheers
Posted on: 2009/9/3 14:24
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: E15 dizzy cap and rotor.
From Cape Town, South Africa
I just had a look for you on my E15 Dizzy, mine only state the Nissan Badge on them with no part numbers.
Quick search on the net revealed the following:
http://www.bosch.com.au/content/langu ... s/Ignitioncatalogue07.pdf - Page 35
Cap - GH506
Rotor - GH600
The best advice will be to phone Nissan or a parts shop and just confirm that part numbers.
Posted on: 2009/9/3 21:32
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Apparently according to the wiki the cap and rotor need to be taller than stock parts.
Has any one used stock caps and rotors? That would be allot easier.
Posted on: 2009/9/3 23:47
72 B110 A14
06 380 VRX
What do you mean with stock parts?
Posted on: 2009/9/4 13:56
www.race-tech.co.za
Factory parts. Basically I'm askin if I was to get a cap and rotor to suit a n12 pulsar, would they fit the dizzy that is adapted to suit an a series?
Posted on: 2009/9/4 15:03
72 B110 A14
06 380 VRX
From hastings,vic
u use stock replacement dizzy parts e15
only bottom half moded
std cap and rotor button
tommo
Posted on: 2009/9/4 15:15
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Thanks Tommo. That's Exactlly what I wanted hear.
Has any one noticed that the wiki says the rotor sits higher meaning a different cap/rotor is needed?
Posted on: 2009/9/5 4:36
72 B110 A14
06 380 VRX
From hastings,vic
if u put e15 guts in a12 dizzy u need a biger cap
have done had to make a rotor buton to fit a12 cap
Posted on: 2009/9/5 5:37
From hastings,vic
wiki not always right, its just a guide.
Posted on: 2009/9/5 5:39
