Re: tacho problem / what the hell did i blow up
Quite a regular
From Inner West Sydney
I can only find one black white tracer in the wiring harness and both sides of my ballast resistor are single terminal.
How do i know which side of my ballast resistor is 12 volts?
Posted on: 2009/9/13 6:34
Im old
Quite a regular
Thanks Dattodude and others, you guys are the ducksnuts !!
Great help and advice much appreciated. Saved me dollars at the sparky's
Cheers
Adam
Posted on: 2009/9/13 7:49
Under the dash, there is only one BW wire. It is 12V coil feed. Wire it through the tacho loop.
The 12V coil feed goes directly to the ballast resistor, from there to the coil. When key is to START, another wire bypasses the resistor.
Posted on: 2009/9/13 7:50
Quite a regular
so i should be able to take a wire from one of my ignition knobs on the instrument panel to the single BW wire looping through the tacho?
Posted on: 2009/9/13 7:57
Im old
« 1 (2)
