Re: A series electronic distributor for sale
From Brisbane, Australia
Interested, PM sent.
Posted on: 2009/5/8 0:37
From Fremantle, West Australia
PM's replied
Posted on: 2009/5/8 17:13
From brisbane
Hi boy's
I installed my electronic dizzie this afternoon and, even with the adjustment cranked as far as possible, it is still sitting about 30 degrees btdc.
What have done wrong?
Cheers Matty
Posted on: 2009/9/13 7:50
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Southern Highlands, NSW, Australia
Whip it back out and install it on the next tooth. That should get you within the range you need to be in.
Posted on: 2009/9/13 7:57
'72 1200 sedan hillclimb/supersprint car
From brisbane
Cheers mate
Will give that a try.
Should I be rotating it clockwise or anticlockwise?
Thanks again Matty
Posted on: 2009/9/13 8:13
Not 100% but you have to rotate it the same direction that it turns when the engines running. Not running a dizzy on my a-series anymore so i've forgotten
Posted on: 2009/9/13 8:18
From brisbane
Cheers mate
Just ducked out to the garage and fixed it up.
Thanks very much for the help.
Matty
Posted on: 2009/9/13 9:10
From T'ville
these look the same as an E15 pulsar dizzy. My 14yr old son fitted one to my b310 picked out an ED falcon coil(pionts coil didnt like it) and wired it in and bobs my uncle. runs as sweet as, cant be too hard?
Posted on: 2009/9/13 9:28
From brisbane
No the wiring in wasn't hard as it only consists of two wires that need to be attached to the coil. I was simply unsure as to why the timing was so advanced after installation. Not having ever removed a distibutor before I was unaware that moving it a spline over was required.
But congratulations to your 14 year old and of course you for fathering him.
Posted on: 2009/9/13 11:06
Is it running OK now?
Posted on: 2009/9/14 13:41
« 1 2 3 4 (5) 6 »
