Browsing this Thread:
1 Anonymous Users
Re: Ok 1000 fans.. |
From Freo
ok I'm getting an order in, 1, Perthute, 1 set inner-outers 2, Matty, 1 set inner-outers 3, Weekend, 1 set inner-outers 4, Jennadat, 1 set inner-outers 5, Stevo, I set inner- outers
looks like the outers that are available are 14mm, having a little trouble with Translations, and cross referencing numbers.. so if you were unlucky enuff to have 12mm outers, the tie rods will need to be changed to 14mm shafts, but getting there,
Posted on: 2009/9/14 16:14
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
Re: *** 1000 Tie Rod Ends *** B10 fans |
From perth airport
sounds all good let us know when you need payment
Posted on: 2009/9/14 22:45
From Perth WA
Put me in as well cheers
Posted on: 2009/9/15 2:41
datsun 1000, Its not the size its how u use it.
From Sydney NSW
Are the 14mm's the same as the 1600 tie rods? Swear i read that somewhere
Posted on: 2009/9/15 3:16
From Coondle, WA Australia
Fark! I am away from the site for a few weeks and look what turns up! Typical.... Now perhaps I will need to take a fall on the Pepsi challange to keep Dundee on the good side.... imm getting closer mike!
Posted on: 2009/9/15 7:50
From Freo
1, Perthute, 1 set inner-outers 2, Matty, 1 set inner-outers 3, Weekend, 1 set inner-outers 4, Jennadat, 1 set inner-outers 5, Stevo, I set inner- outers 6, 1000 coupe 1 set inner outer 7, Reuby, 2 sets Inner outer
Posted on: 2009/9/15 9:29
From Freo
hmm interesting find, snapped up a pair off the bay, 14mm outers,
turns out every tierod I have here early late or otherwise is 12mm in and out..
from 67 onwards, sedan wagon coupe,
apparently the genuine parts book only lists one,
so the 14mm listings may be a myth,
Posted on: 2009/9/16 15:43
From newcastle, NSW
is this still a go ahead?
Posted on: 2009/9/22 10:01
From newcastle, NSW
Posted on: 2009/9/23 11:20
