Re: does any one know about a13
From Christchurch New Zealand
we own a nissan forklift company in CHCH so now i am going to set you all straight about the forklift myth there was an A12 most commonly knowen as a D11 i can get std flat top pistons for them and there is a A15 engine in a forklift
Posted on: 2003/9/24 6:29
"If your not living on the edge your taking up too much space" Rod Millen
From tassie
well the two i have have a bore size of 76mm and a guy who was going to do it up for me said they were to bored out to work with but to this day i still havent found any specs and thanks every one for ur help
Posted on: 2003/9/24 9:02
From Millgrove Vic OZ
Watto They are ok to use as I have one at 76.8 mm. If you want to sell them I am interested and will be over there in Low Head (Near George Town) in about 5-6 weeks. Where are you located?
Have swap parts, will travel
Posted on: 2003/9/24 9:36
Cheers Feral
From Wellington New Zealand
Aha D11 >>>I should have read this before trundling off to my workshop to find the manual. Sadly my book has got wet and the pages have stuck together..I will try drying it out and digging up some part numbers. Those flat tops are the pistons some ministock racers got caught using aren't they???
Posted on: 2003/9/24 9:42
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Hey Feral
If you DO get them, then keep me in mind. Do you remember what i wrote to you about before in relation to the A13?
Just say NO & i will refresh your memory, by direct e-mail
We have an A13 block over here & i will be rebuilding it into a running engine for my youngest sons 120Y, using all the rotating / reciprocating bits from my 1200 mill, but i need some bits for that same engine. It's going into my KB10
Chris
Posted on: 2003/9/24 10:47
Love your Datsun.
Treat it well.
« 1 2 (3)
