A14 with a problems :(
From Selangor, Malaysia
hi guys,i have a problem here..
now my b210 is running with rebuild a14 engine+twin solex 40's,but i can't rev more than 5k rpm..it seems like not enough of fuel supply to the carbies or spark (my guessing ) when i rev it hard..i've changed the distributor from contact point to electronic distributor and coil too..
but its still the same..
what is the problem here?i've no idea to settle this out..please shed a light to me :)
Posted on: 2009/9/25 7:20
dying to learn A series..help me :)
Re: A14 with a problems :(
From Christchurch NZ
Does it sputter and die above 5000, or will it just reach 5000 and not rev any higher?
Posted on: 2009/9/25 7:36
Forced Induction!
Yes,it does sputtering but the engine not died..it cant rev more than 5k after reach it..
Posted on: 2009/9/25 8:07
Is the float leval in the carburators set high enough?
Posted on: 2009/9/25 8:12
Forced Induction!
not too high and not too low..
is the sputtering is caused by the fuel? do u mean that the engine is not getting enough fuel or too fueled?
Posted on: 2009/9/25 8:22
From Perth WA AUS
Perth ute had a very similar problem I think he sorted it out somehow ask him.
Posted on: 2009/9/25 8:55
Datsun 1200 2Dr sedan.
thanks guys..
any suggestion would be very appreciated
Posted on: 2009/9/25 9:09
[url]http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=42069&viewmode=flat&order=ASC&type=&mode=0&start=0[/url]
i guess the answer is in here..thanks all
Posted on: 2009/9/25 9:34
