drop spindles
From cold toast
just wondering if anyone has heard or noes of some off the shelf items for a 1200 ute
if not, do they have any idea what a custom set would be worth?
cheers
Posted on: 2009/10/6 11:37
Re: drop spindles
never heard of drop spindles for a 1200 before, ever
Posted on: 2009/10/6 11:41
Re: drop spindles
From cold toast
yeah neither, but worth a try :)
Posted on: 2009/10/6 11:42
Re: drop spindles
From perth
1200's have macpherson struts
dropped spindles are used with A arm suspension
Posted on: 2009/10/6 12:27
Re: drop spindles
From Geelong, Vic
? drop spindles?
as in the type that mini truckers use, that is compatable with double A arm type front ends?
to get the same affect with a 1200s front end just get lowered springs and come bump steer spacers. this will make the stub axle higher and the car lower whilst keeping the control arms in the same position
EDIT, geez daz way to just sneak in with the short answer
Re: drop spindles
From cold toast
oh dammit
Posted on: 2009/10/6 12:51
Re: drop spindles
From perth
not dammit, you get the same result just need different(cheaper)stuff
Posted on: 2009/10/8 12:34
Re: drop spindles
From pooraka,,adelaide
so u mean tortion bars right???
my 620 ute has them
Posted on: 2009/10/8 22:21
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Re: drop spindles
From Geelong, Vic
torsion bars are the springs in most double A arm setups
completely different to what 1200s have
in 1200s you have coil springs...get lowered springs and that will lower your car
Posted on: 2009/10/9 3:50
