« 1 (2) 3 4 »
Re: need help with my a14 turbo
From perth airport
decomp = less power :(
Posted on: 2009/10/15 9:57
perth airport parking
Datsun 1200 ute A14
From Perth WA AUS
Decomp = more boost or more reliability!
Posted on: 2009/10/15 9:58
Datsun 1200 2Dr sedan.
From Perth WA AUS
Running 10psi without pinging I think the motor is decomp'ed allready, but a little bit more might make it safer to crank up the boost a bit.
Will need to be dyno'ed though for the fuel side of things.
Posted on: 2009/10/15 10:05
From Perth WA AUS
If you can stretch the budget a bit a Wolf 4D computer with hand controller will give you hugely more accurate fuel & ignition settings at more points in the rev range, also you can switch between race and road settings or make adjustments on the go.
Posted on: 2009/10/15 10:15
From perth airport
im told motor is stock straight from a sunny with low k's and tap's the lines for the turbo and lost interest . i like the tune in it but not wantin to spend much on it has that is wat the utes for and i dont wanna be braking stuff allthe time
Posted on: 2009/10/15 10:22
Datsun 1200 ute A14
From Perth WA AUS
You have most of the stuff for a strong drive train.
Posted on: 2009/10/15 11:00
From perth airport
yer im just worried about how long will the motor last hoping someone can help me decide weather its gonna last with a nismo head gasket n arp studs or its gonna need the internals set up for turbo :? . im 50/50 atm on keep or sell has im getting a skyline in the next few weeks and they dont brake lol
wat to do wat to do
Posted on: 2009/10/15 11:08
Datsun 1200 ute A14
From newcastle, NSW
AHHHHHHHHHH!!!!!!!!!!!!!!! Sounds to me like your in the same boat i was arond november last year, I got sick of blowing diffs and axels, i thought i have to re-engineer the car arond the engine which is what i did, and i'm still doing!
Go the T-50 for sure! A-series boxs don't like too much boost, as you have found out! i would recomend a good quality clutch for it as well.
I found that you only really need to decompress the engine if you want to run big boost, i ran 8-10 psi for ages with no detonation problems, but that was through a carby. I recommend getting a good tune to get the EFI running perfectly, Espeically if its a daily driver.
How well did it go befor the clutch and diff gave way?
Posted on: 2009/10/15 11:10
From Perth WA AUS
It was quite fast, to say the least. I agree with Jordy on the 14second quarter time.
Posted on: 2009/10/15 11:23
From Perth
Personal opinion here
Pull the motor apart now and check the bearings for signs of detonation
Chances are you have already lunched the pistons and rings anyway
When your happy with the bottom end put it back together
If its got stock pistons in it now your as decompressed as I'd want to go without making it doughy off boost
With all those crazy injectors on it maybe you should make one of them pump a methanol/water mix to help cooling intake temps and providing more bang for your buck
Then get it tuned to suit
Thats what I would do if it was me and you weren't looking to spend huge on reinjecting it and building it for boost
As for the clutch and box...I'd use the T50 but its not going to handle abuse much more than the stock box
And if you use the clutches Dellow says to use they use the standard A pressure plate so its no bigger or better than what you have
Unless you get the flywheel redrilled for a Toyota 200mm clutch like mine is
And if you lighten the flywheel it will rev faster.... might take your ankles off if you take too much off it though
And Skylines do break... often... and they cost more to fix
Posted on: 2009/10/15 11:32
« 1 (2) 3 4 »
