« 1 ... 967 968 969 (970) 971 972 973 ... 1777 »
Re: PERTH BOYS.. GO THE DATTO
From perth airport
Posted on: 2009/10/15 12:15
perth airport parking
Datsun 1200 ute A14
From Perth WA AUS
Its very popular up north:)
Posted on: 2009/10/15 12:21
Datsun 1200 2Dr sedan.
From Perth WA AUS
I think I broke Popo!
Posted on: 2009/10/15 12:22
From perth airport
hahahaha finaly he know a days work :P
Posted on: 2009/10/15 12:24
Datsun 1200 ute A14
From Mandurah, Western Australia
Jordy , What ratio diff did you have in the ute with your CA?
Posted on: 2009/10/15 12:29
From perth airport
hmmm stock h165
wat was the go with the coupe you have ya ratio's outta wack? somethin must be wronge . wat revs where you changing at ? crossing the line in 4th? wat speed's where you getting at the finish line ?
should be in the 13's
Posted on: 2009/10/15 12:42
Datsun 1200 ute A14
From Willy Wonkers Chocolate Factory
yeah should be alot quicker.
Posted on: 2009/10/15 13:11
A15 Sonny, its got a A15t
packing fudge excites me ......
Crossing line in 5th @ 135 kph and pulling 5500 plus RPM.
Running a 3.89 Borg Warner. The H165 I think is 4.11 and so to is the skyline Borg Warner from memory.
Maybe the final drive in the gearbox has been changed?
Posted on: 2009/10/15 13:21
From perth airport
5 gear across tthe line :?
in a silvia 1st gear 60kph second 115 kph
i allways pass'd the line just has it need'd 4th gear
sounds like thats your problem
u do take the ca to 7500rpm?befor changing ?
Posted on: 2009/10/15 13:30
Datsun 1200 ute A14
Pulling about 6000 on changes, it wont do 60 in first.
Posted on: 2009/10/15 13:34
