Re: need help with my a14 turbo
From Perth WA
imho the pistons on the a14 are as tough a crown as just about forgies, ive seen them bend up valves and pushrods with hardly a nick on them. tomorrow is a 35 degree day good time to know if it pings.
so unless its pinging dont bother decompressing or it will be too laggy, since they are fairly low comp stock anyway, drop the boost a touch with the new gasket and use an IC or water inj and u should be fine. U already have the parts to toughen the weak links.
Posted on: 2009/10/16 5:56
datsun 1000, Its not the size its how u use it.
From perth airport
cant test it atm lol no clutch or diff :)
it runns a front mount intercooler .
looks like new box flywheel n clutch new diff slap a head gasket in and see if it happens again
Posted on: 2009/10/16 6:05
perth airport parking
Datsun 1200 ute A14
From Freo
now you've had 12psi+ it will be hard for you to tame it down to a reliable 8-10...
Posted on: 2009/10/16 7:44
A15 PSI Project Motor
'72 CB750k,
From Perth WA
theres a subtle hint hehe
Posted on: 2009/10/16 8:07
From Perth WA AUS
I've got that head for you, when you see the light:)
Posted on: 2009/10/17 12:06
Datsun 1200 2Dr sedan.
From perth airport
wat head ? i have 3 oval port heads
Posted on: 2009/10/17 12:12
Datsun 1200 ute A14
From Perth WA AUS
Oh you prob'ly dont need it then, low comp head.
Posted on: 2009/10/17 12:27
From newcastle, NSW
is your motor stock stevo?
My A14 is 40thou over running stock pistons, i'm currently running a decomp plate to lower the CR a bit. I'm only running 12psi never had any detonation problems.
Posted on: 2009/10/18 10:50
« 1 2 3 (4)
