« 1 (2)
Re: wrecking 120y
From bathurst nsw
its a bit too dark at the moment to check for sure so ill check it in the morning and let you know. im assuming you would require both sides?
Posted on: 2009/8/3 9:07
My car gets me from A to B...Just faster ;)
Re: wrecking 120y
From Townsville, Qld
no just the drivers side. It seems petrol leaking from the filler stayed in that spot and let crap build up and rust.
Posted on: 2009/8/3 9:19
Re: wrecking 120y
From bathurst nsw
hi guys sorry to get back to you so late.
littledarkone: ive had a look at the area, it has surface rust and barely passed the screwdriver test, and the sweige line and most of the arch around the wheel is made of bog so its probably a no go, sorry mate.
andy: unfortunatly the other 120y had completly stuffed castor rods (it had been rolled) but the kink in this one looks like i could straighten it in a vice. ill take it off today and try and let you know how i go.
most parts still available except the gearbox and most of the front grill and bumper stuff.
Posted on: 2009/8/8 3:42
Re: wrecking 120y
Im looking for a Tachometer, radio knobs and the glove box door with hinges.
Let me know if you have these also I'll need shipping to Hawaii. Thanks.
Posted on: 2009/8/14 5:56
Re: wrecking 120y
From BULLI -Wollongong
HI Buddy
I am chasing a pedal for the accelerator. Can you help?
Cheers
Learner/Michael
Posted on: 2009/10/17 11:35
Re: wrecking 120y
From BlueMountains NSW
Gday Kurt
do you have an interior ceiling light cover and the plastic covers for seat tilt adjuster. Cheers Bazz
Posted on: 2009/10/18 0:23
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
Re: wrecking 120y
From mandurah
hey how much for the front struts
Posted on: 2009/10/21 12:58
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: wrecking 120y
From cold toast
got a tacho?
Posted on: 2009/10/22 0:20
« 1 (2)
