Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
sc 12/ sc 14 blower oil
supafatto
Posted on: 2009/10/21 11:41
i sorta need some cheap oil for my sc 14 supercharger b4 the weekend any ideas as im low on funds to buy from toyota and i wanna put setup in this weekend :)
any ideas please pm me thanks nick
#3
Re: sc 12/ sc 14 blower oil
ROConnor
Posted on: 2009/10/21 11:45
any Idea of the caractoristicks of supercharger oil?? miaght be able to use motor, gearbox or diff oil?? probly something that handels high temp's..
#4
supafatto
Posted on: 2009/10/21 11:57
was told something like this but cant afford to buy 20 ltr
the 5w-30 variant is the one to go for (not because of it being slightly thinner at room temp, but because it has a different additive package which makes it better for manual transmissios with synchro rings, so that you can optimally offset the cost of having to buy it in larger quantities (they might do smaller than 20 litres, but I'm not sure) by being able to use it as gearbox oil as well.
#5
Dundee1000
Posted on: 2009/10/21 12:04
we use redline gear oil in Sprintex SC's, not much else can keep up, and oil level is CRITICAL, a 10ml change over or under the level will destroy gears..
#6
aidaniel
Posted on: 2009/10/21 12:29
well the dip stick on the sc14 has a good 30mm between H and L
#7
jmac
Posted on: 2009/10/22 2:48
don't use diff oil it has additives for hypoid gears (gears that aren't centred axis to axis - like diff gears - where the teeth slide across one another - it's not the best for anything else. Additionally, the viscosity is rated differently, at 100C it will thin out to something like 5w30 motor oil (or roughly dexron auto trans fluid).
About the best gearbox oil I know of is Shell Donax TD in 5w-30. It is used in industrial and agricultural machine gearboxes, and a friend via the internet who also operates fleets uses it in (in his words) everything that has a manual gearbox. In essence this is the sort of 'treatment' the oil would be subjected to in the supercharger. If I couldn't use Donax (it's not available in smaller containers, but at least you could use it in the gearbox in the car as well) I'd suggest auto trans fluid - probably dexron. Dexron itself is up to what - 5 or 6, and although it's backward compatible, it is thinner than dexron 2d was. I think Transmax M (or something like that) is one of the few still available dexron 2 spec auto trans fluids, but might be getting the name confused.
#8
supafatto
Posted on: 2009/10/22 8:59
goes any one no where to get ie dundee i sorta need buy saturday :)
