s13 front brake conversions (register interest)
From northern 'burbs adelaide
in coming weeks i will be modifing a set of 120y struts and s13 discs and calipers for myself and maybe someone else. i thought that if there was anyone else in adelaide without the resources or know how to do this then i could do a couple more sets as well. depending on how many people want this done wil determine how much it will cost.
if you are interested let me know. you will need to supply the following items:
-120y struts and hubs
-s13 discs and calipers
-8 pintara studs (i can supply these to for an additional cost)
i wont be machining the actual rotors so either supply new or get them machined at a brake place or mechanic
make sure you get a matching set of calipers an rotors as there are a few different types but they all bolt on the same. also note that you may need to upsize your wheels depending on setup size.
for those interstate i will be making extra brackets that i can send out to you but you will need to get your hubs machined locally
please pm your interest so i can determine how many sets to make
brackets will be $40 a pair and if you buy more then one pair postage is free. they will be ready mid to late next week
Posted on: 2009/10/22 3:15
Edited by aidaniel on 2009/10/24 10:46:11
Edited by aidaniel on 2009/11/15 1:30:56
Re: s13 front brake conversions (adelaide only)
From Melbourne, Aus
Can you make a couple extra of the brackets that mount the s13 calipers and send them to Melbourne?
cheers
Bruce
Posted on: 2009/10/22 23:07
From Sydney
Dont forget there are two variants of S13 rotor and caliper combos. Earlier S13 with CA18 fitted has the 250mm rotors and matching calipers and the later model S13 with the SR20 engine has the larger 280mm rotors and matching calipers.
The same mounting bracket can be used with either brake combo. I went with the 250mm brakes as I wanted to still be able to fit 13 inch rims.
cheers
benny
Posted on: 2009/10/22 23:41
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
so they use the same mounting points ... i was worried about that but it looks like there is no need to.
i know there is a bloke in qld who makes the brackets and i dont wanna rain on his parade but if there is interest in more brackets that will bring the costs down
Posted on: 2009/10/22 23:48
From Mildura, VIC
Im interested
Posted on: 2009/10/23 11:04
From mandurah
ill take 2
Posted on: 2009/10/23 14:31
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
ok so it looks like there are people interested in only the adaptor brackets so im gonna make up a batch of these ... but im also offering adelaide people machining of the 120y hubs to suit the discs.
please pm me if you what a set converted or if you only want the brackets so i can keep a tally and it will make it easier for me to organise postage to those interested
Posted on: 2009/10/24 5:30
From Mildura, VIC
Id like a set coneverted. BUT, Im not in adelaide
Posted on: 2009/10/24 9:02
From SYDNEY,NSW
i know it says adelaide only, but would you please consider posting to sydney? i NEED a pair of brackets...
also what price are we taliking here?
Posted on: 2009/10/24 9:48
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
i can send brackets only interstate but you will need to get the hubs machined locally. with the adelaide bloke i can machine the hubs as well ... when i know numbers i will let you all know prices
Posted on: 2009/10/24 10:24
(1) 2 3 4 5 »
