« 1 (2) 3 »
Re: blown setup in need help
stock pump wont put out enough pressure for boost, you should have gone elec with a pressure regulator.
4psi fuel plus 10psi boost needs 14psi fuel pressure almost from memory
Posted on: 2009/10/26 9:14
its draw through setup so doesnt need that much pressure but i could do with an elec pump u offering one mik? :) need that cluch i think the one i got either slips under boost or i spun the wheels and didnt feel it ??????
Posted on: 2009/10/26 9:25
Car free
From sydney
I think thats your problem dude. 15psi and no water/methonal, intake temps will be way to high. You could try richinig it right up I guess. What a14_force said is the way to go, just get an a/f ratio meter and go for a drive. At least you will be able to see whats doing. You could even try a bottle of octaine booster and see what happens.
Posted on: 2009/10/26 10:03
Edited by go1200 on 2009/10/26 10:26:26
Edited by go1200 on 2009/10/26 10:27:51
any idea wat jetting ppl ran and wat size emoultion tubes?
need to get that water sprayer in any one have a spare ress bottle and a little time to install for me??:)
Posted on: 2009/10/26 11:14
Car free
any ideas on jetting and timing settings?
Posted on: 2009/10/26 23:53
Car free
For the timing:
Naturally apirated: 35 degrees total advance at 2400 RPM or higher, full throttle
Boosted: 28 degrees total advance is a good ballpark figure to start with
Jetting for which carburetor?
Posted on: 2009/10/26 23:56
jetting is for a 32/36 dgav
Posted on: 2009/10/27 7:38
Car free
also wat is a good static timing i should set. If total is to be 28 with boost, i have an e15 elec dizzy.
Posted on: 2009/10/27 8:10
Car free
From Melbourne, Oz
Im gona sugest if 35 is total for a Standard 1200 and I think base timeing is about 8 degrees if you run 1degree at idel you should get ya total 28??
Posted on: 2009/10/27 9:52
"I hav achieved wood"
Treat it like a turbo motor. Lock the dizzy and set the base timing to 20 degrees. Unless you have an E15T dizzy which will have boost retard. Then you can set the timing normal.
Posted on: 2009/10/27 11:11
« 1 (2) 3 »
