« 1 (2) 3 4 5 ... 10 »
Re: D.I.Y. Dyno
Hi sikyne,
am also planning to build a hub type dyno just like the dynapack style, i have lot of thoughts in mind, am a computer programmer, and currently am putting the first steps of the Data acquisition that i will be using along with my own used software that will be based on C++ with visual libraries, i have mostly all sensors and controls taken into consideration, AFR, MAP, EGT, Temp/humedity with correction, RPM pickups, PWM controller, and torque sensing, also i got more advanced sensors to work with, like oil pressure for gear box and engine, fuel flow, and air flow rates for turbo and supercharged cars, and coolant pressure with temp.
i don't know if you mind exchanging ideas about this hub dyno, to come-up with one advanced unit.
Posted on: 2009/10/22 7:31
Re: D.I.Y. Dyno
From Ballarat Victoria
FastButBlind, you have a PM.
Posted on: 2009/10/27 12:59
VIC DYNO HIRE
Re: D.I.Y. Dyno
The retarders have arrived. The frames are well under way. Open in new window
Posted on: 2009/11/3 21:12
VIC DYNO HIRE
Re: D.I.Y. Dyno
great work, not many people would go this far with all this. I see ddatsun club dyno day and cruise happening to test it out ;)
Posted on: 2009/11/3 23:28
Re: D.I.Y. Dyno
Great idea!
Bit of a BBQ lunch to go with it, sounds good.
Being a hub type dyno, Might be a little slow changing cars over as it is more of a development tool than a dyno day dyno.
Im trying to have it done before Xmas but might be into Jan before we could have a dyno day.
Posted on: 2009/11/4 4:58
VIC DYNO HIRE
Re: D.I.Y. Dyno
im a master at changing wheels pretty quickly now too lol
Posted on: 2009/11/4 9:32
Re: D.I.Y. Dyno
sikyne you got PM
again sorry for being late
Posted on: 2009/11/11 7:10
Re: D.I.Y. Dyno
Things are progressing well with the dyno. Should be ready for some basic load testing before the newyear.
Ive picked up a great dyno fan, but the motor is a bit small. Does anyone have a large (10HP +) electric motor lying around???
Posted on: 2009/12/10 10:53
VIC DYNO HIRE
Re: D.I.Y. Dyno
what you dont have any spare a1o's sitting around doning nothing lol
Posted on: 2009/12/12 10:12
Re: D.I.Y. Dyno
From SE Melbourne
If you have it up and running after Jan 5 I'd be keen to drop up and have a look at it, your car and talk to you about economical ways to blast paint and rust of the boy's 'rana.
Posted on: 2009/12/12 10:53
Mildman, Datsunless
