need to borrow valve compressor, adelaide :/
From Adelaide, Australia
hey guy just need a valve compressor to change my valve stem seals. can anybody help :/
Posted on: 2009/11/7 3:12
Re: need to borrow valve compressor, adelaide :/
From SE Melbourne
if no-one can lend you one I know they aren't too much to buy
http://cgi.ebay.com.au/VALVE-SPRING-C ... ories?hash=item53dd982761
bout $40
I know it's a bit of a waste if you only use it once
Posted on: 2009/11/7 9:13
Mildman, Datsunless
If it's still on the engine, you can do what I always do:
1. remove spark plugs
2. feed clean small-diameter soft tubing
3. turn crank until piston stops
4. change the seals
5. repeat next cylinder
The tubing inside the cylinder holds the valves from falling down.
Posted on: 2009/11/7 18:38
From Sydney, Australia
or you can do what I did to change valve springs and retainers in my CA, by pumping the cylinder full of air with piston at TDC.
I got an old spark plug, and busted the ceramic part out, and then braised in a fitting that is the same as the tire valve stem.
Posted on: 2009/11/7 20:31
nah the heads of. ive just got a limited budget :( so the rest of the $ i gota spend new bearings, rind\gs and gaskets
Posted on: 2009/11/8 7:50
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Maraylya nsw
i know how it is working on a budget i had to buy a decent valve spring compressor on thursday, cost m $90 now im broke and needing gasket kit and piston rings soon aswell my bloke and internal waiting at the machine shop with a bill at $450
it can be hard at times
Posted on: 2009/11/21 13:00
sr20de out of s13 written of silvia under way
making progress on the 1200 coupe;)
