« 1 (2)
Re: L18 Conversion done, BUT couple of issues...
From Adelaide, Australia
would different size/profile tyre fix the speedo or is it way 2 much out?
Posted on: 2009/11/8 22:42
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Mildura, VIC
We used a cutdown Series 2 Bluebired Rad with a 12 inch fan mounted on the front of the rad, behind the grill. - Works weel, never gets over half.
Posted on: 2009/11/8 23:00
From Mildura, VIC
Tacho working now, thanks tommo73
Posted on: 2009/11/9 1:14
From Mildura, VIC
New problem, tacho working, but car runs like crap with it working & coil gets hot. - Disconnect it, Car runs fine...
Gr...
Posted on: 2009/11/9 2:17
From Geelong, Vic
to much, or not enough power getting to it?
easiest way is to just use a stock coupe dash loom and it should all work fine
and an L20b isnt a good fit without knotching the crossmember. would might be able to get it in there and just be able to clear the bonnet, but it would be a far from ideal fit
Posted on: 2009/11/9 4:04
« 1 (2)
