Gandalf wrote:
Thanks again John
My head is a little bit ported, but still be a round port head.
This is just the standard small port, small valve cylinder head. It will be great for a low power economy engine, or you can spend a bundle on it with port enlargement & larger valves to make it about equal with an original stock A15 head, which would be prefered if it isn't the California smog version.
Try to find a serviceable A14 or A15 head without the air injection feature & this will go a long way towards improving performance as it comes with bigger ports & valves than the A12 head.
Using the A12 head will be like running a race with your fist in your mouth, neither you nor your engine will be able to breathe properly.
The standard compression ratio for many A series engines is about 9.5 to 1. For street use, about 10 to 1 is a good number, particularly with declining octane ratings or rising prices for high octane fuel.
