Mechanical Oil Pressure Sender ?
From Sri Lanka
Hi Giys
Just looking for a Mechanical Oil Pressure Gauge, Can any one tell me from this Sendor , to which side the oil pressure gauge should be connected for this Pics attached, how it is calculating the pressure through a pipe line ? if so how to connect it ? i got pics i don't have tool to decrease it's size can any one help me pls
thanks
regards
Sumith
Posted on: 2009/11/9 8:31
Re: Mechanical Oil Pressure Sender ?
With a mechanical oil pressure gauge, there is no sender. The gauge is connected directly to an oil passage.
Posted on: 2009/11/9 20:10
From Perth WA AUS
Remove your old sender unit from your oil pump and screw in the line/fitting for your mechanical oil guage then just follow the instructions ( If any!)
Your standard oil light will not work any more though, if this is a problem you might need a "T peice" fitting so you can connect both.
Hope this helps.
Posted on: 2009/11/10 13:04
Datsun 1200 2Dr sedan.
From Sri Lanka
Hi levey
Look at this Pic, just see whether i can see both with the existing setup or do i need t socket on it
thanks
regards
Sumith
jpg  22.jpg (55.08 KB)
10994_4afa2f569db1c.jpg 448X336 px
Posted on: 2009/11/11 3:28
Yes, it is best to use a Socket to remove the old sender. But a closed-end wrench works too.
If you with to connect the oil gauge line, and the sender, you can use a plumbing "T" like this:
Oil pump
Posted on: 2009/11/11 5:42
From Perth
And don't use nylon line
get a copper line kit
Posted on: 2009/11/11 5:50
