Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Sloopy Loosy Wheel
Sumith
Posted on: 2009/11/11 3:44
Hi Guys
I have Noticed my left side wheel is not moving straight.feel is is sloppy while turning, tried to remove it and fixed it,when i am tightening it from a wrench i felt the there is a little play (horizontally)on that particular wheel , what do you think guys what would be the reason ? Thanks Regards Sumith
#2
Re: Sloopy Loosy Wheel
aidaniel
Posted on: 2009/11/11 5:03
sounds like a wheel bearing mate ... grab the top and bottom of the wheel when the car is jacked up and see if there is excessive play ... if so then just replace the bearing
#3
Sumith
Posted on: 2009/11/11 5:39
Hi aidaniel
I checked it in Vertical way from top to bottom . there is no a considerable play on it,but when i check it from horizontal way (from left to right) vice Verse, there is a considerable play on it ,means when i try to tighten the wheel studs the wheel moves left to right vice versa Thanks regards Sumith
#5
aidaniel
Posted on: 2009/11/11 5:50
do both move at the same time? if not check the ball joints (tie rod ends) on the steering arm on that side to see if they have let go
#6
Posted on: 2009/11/11 5:57
Most likely it is the steering linkage (tie rods) and not the wheel or bearing. Have someone wiggle the steering wheel while you lie on the ground and watch the linkage. If it moves before the wheel does, the sloppiness is in the linkage.
