Browsing this Thread:
1 Anonymous Users
Twin su or single 45mm side draft for l20b? |
From Mildura, VIC
Guys, as I stated in my other thread, Im considering l20b into 1200. Ive go a set of 180b twin su's and a single 45mm weber. The engine will remain mostly stock, but may end up with a ported head and a mild cam one day. So guys, what would you fit? Su's or the weber?
Posted on: 2009/11/13 5:31
Re: Twin su or single 45mm side draft for l20b? |
From Perth WA
I would use which ones are in better condition or been used most recently otherwise might need expensive rebuilding. I was looking at books on tuning both webers and SU and both are thick books and seem like a science in themselves.
I have a redline single weber manifold for L series if u use the weber and dont have one.
Posted on: 2009/11/13 5:40
datsun 1000, Its not the size its how u use it.
From Mildura, VIC
Thanks, but ive got all the gear for both set-ups.
Posted on: 2009/11/13 6:01
From Mildura, VIC
Anyone here got an l-series in a 1200 running a single s/d? Any pics?
Posted on: 2009/11/13 9:35
im going su's on my set up, only cause ots stright lpg and already have the set up on the a15 su manifold (will bolt onto L16 one too)
Posted on: 2009/11/13 10:32
From Adelaide, Australia
i would take the webber anyday. they preety much are the same thing (twin carbys) but the webber is so much easyer to get parts to tune it.
Posted on: 2009/11/13 11:17
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
Ok - this is a big if - but if it's just a single weber - the main 'gain' from webers (well aside from the fact they are a pretty decent design in general) is where you have one carb throat per cylinder/intake port. If you don't have that (which you won't with a single weber) then the gains over twin SUs is much smaller. THe weber (if you optimise both setups) will still outpower the twin SUs, but not by very much, and i'd bet money nobody would be able to tell without lifting the bonnet, just by driving.
the big if, however - is as Matto says - the weber is easier to setup (since it's a matter of altering jet, idle jet, emulsion etc (though I'd bet you'd get the emulsion right in 1-2 goes tops), With SUs, you need to buy 2 needles per 'experiment' till you get it right. If it were decades ago, more than a few workshops would have enough needles on hand that they could dial it in and just bill you for the time and final needle choice, but now, good luck, and the needles are expensive all things considered.
That said, try giving SUmidel (I think there is a website too) a call. They are (or were) a firm in NSW if I recall, who specialised in the SU carbs and might just have enough experience to get you right in the ballpark as far as needle selection, possibly enough to be acceptable (if not perfect) for a lot of apps.
Posted on: 2009/11/13 22:09
John McKenzie
From Mildura, VIC
I'm leaning towards the single 45mm webber at the moment, just for the simpicity more than anything else.
Posted on: 2009/11/13 23:38
From bend oregon
run the su-s i run them on my L-18 work great
Posted on: 2009/11/14 0:20
From bend oregon
air filter use k/n part number 569096 with min mod to bolt holes on base plate
Posted on: 2009/11/14 0:23
