Addco rear swaybar & Adjustable front strut mounts.
From South Africa
Addco rear swaybar part #225, listed to fit Datsun/nissan 1200, It doesnt fit... i dont know if i got sent the wrong bar or if its for a coupe or ute, but it definatly will not fit my B110 sedan... The Addco front bar went in no problems.
Does anyone know if its coupe or ute fitment only? secondly does anyone have a picture so i can confirm if its right or not.
Secondly, front camber adjusters up top, somthing that will not effect ride height as the car is perfectly ballanced now and going to coil over is not permitted. I also really do not want to slot the body! anyone know of somthing or pics or anything?
Thanks
Posted on: 2009/11/16 7:06
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
Re: Addco rear swaybar & Adjustable front strut mounts.
From Melbourne, Oz
I hav seen hight adjustable camber tops from an s13 silvia used on a 1200. I think it was someone in malasia?
Posted on: 2009/11/16 7:23
"I hav achieved wood"
From South Africa
I have a set of D2 camber plates for a S13, problem is no matter how I do it, it raises the front end up Other Option is to remove the whole rubber damper and use some thick ally and make a solid upper mount with the whole offset for the camber.
Posted on: 2009/11/16 7:31
'07 Hilux - Tow car
From Melbourne, Oz
maybe get some good qualit bolts and make up a spacer and a saport ring, and mount the cambertops above the tower? (thr ring for the underside soyou dont pull the bolts threw the steel)
Posted on: 2009/11/16 7:47
