« 1 (2) 3 4 »
Re: My B10 A15 4 door streeter
From Armidale N.S.W
Ha thats cool as mate sits nice
Posted on: 2009/11/19 2:02
73 1200 wagon SOLD
That sounds pretty good. Sounds pretty responsive too with the big Weber hanging off the side.
With that video I can now judge how low the car is, it's almost a belly scraper. Nice work.
Posted on: 2009/11/19 3:35
Oi, is that a clock attached over the steering column? Or is it a little tacho.
It looks like the factory option clock, if it is do you want to sell it??
Looks like you have a complete boot badge too......envious is me.
What size exhaust system is that? It's pretty ballsy.
Posted on: 2009/11/19 3:39
From Freo
it's a tach in the big pic..
factory option clock is pedestal mount on the dash top..
Posted on: 2009/11/19 4:35
A15 PSI Project Motor
'72 CB750k,
From Sydney NSW
yeah just a tach, the exhaust is 2", i love it.
DCOE 45 hanging off the side, its very responsive, everything EFI i have had wont touch it.
Just checked then on the head though, always assumed it was an oval port, its not.... its an M30, so round port which would account for some of the low speed torque. Damn. Why would my A15 be fitted with this head?
Posted on: 2009/11/19 8:02
You might have the Thrift version A15. I suppose if you take the rocker cover off and check if it has '13' on the head bolts this is a pretty consistent indicator of a thrift engine, but you made ought to wait for some other advice. All the thrift engines I have had (and seen) have had the 13 bolts.
That isn't a biggie as it helps (as you said) with the lower revs.
It certainly sounds responsive.
Posted on: 2009/11/19 8:13
From Freo
they must have ported the manifold, as the redline/warneford manifolds are for 40's..
Posted on: 2009/11/19 8:16
'72 CB750k,
From Sydney NSW
Interesting stuff. Seems like a bit of a waste to port a manifold and stick with a smaller head.
I do have 13's on my head bolts. Its not so bad though because now I know with a larger head I could really get this thing moving!
Posted on: 2009/11/19 8:25
Your 45 might not be as responsive with the oval port heads.
You might want to look into slight porting your round ports and
cleaning up the dags, especially the exhaust short turn radius.
Some rallye guys I met in the past praised the round port heads.
It all depends what you are after as beyond this even if you gain
10% more using oval port heads your pockets might say enjoy it as
it is: a well balanced and fun streeter.
Posted on: 2009/11/20 1:49
From Perth WA
D can u please elaborate what u mean about the "exhaust short turn radius"
I have a low drop a15 exhaust manifold i was going to use in place of the a14 manifold in order to clear the lynx crossover manifold for single weber that hits the stock manifold.
the low drop a15 exhaust manifold looks a lot more restrictive especially the sharp turn straight out of no 2 and 3 cyls and i was going to try and port and smooth all this and see how it goes, r u talking about the same thing?
Posted on: 2009/11/20 2:03
datsun 1000, Its not the size its how u use it.
« 1 (2) 3 4 »
