Please need help
From mauritius
I have a vauxhall chevette,but i have a datsun a14 engine on but the problem is that my spark plugs are getting black of carbon every time an the engine start making like "Volkswagen Beetle" when idel an in low acceleration. Please help me!
Posted on: 2009/11/22 22:39
Re: Please need help
Is it a dry flaky black, or a wet gooey black?
Posted on: 2009/11/22 22:40
From mauritius
Its often wet with dark fuel, but not oily
Posted on: 2009/11/22 22:48
This sounds like a fuel-fouled plug.
The most common cause is if the choke is stuck partially closed.
1. Ensure that right after starting the choke opens partially (at least 1/8 inch)
2. Verify that when the engine is fully warm, the choke is perfectly open -- straight up and down.
Posted on: 2009/11/23 1:33
From mauritius
The choke is not connected in the car so it is always open, I have stock carb that is hitachi DCH-306. Am using denso w16ep-u on this engine.
jpg  Image black spark plug.jpg (61.57 KB)
12606_4b0a488055661.jpg 1528X960 px
Posted on: 2009/11/23 7:41
Edited by aruneshal on 2009/11/23 8:32:00
Edited by aruneshal on 2009/11/23 8:34:37
From Perth WA
tune your carb for idle mixture and speed to start with.
Posted on: 2009/11/23 7:47
datsun 1000, Its not the size its how u use it.
The first step -- before setting mixture -- is 1) verify ignition timing (5-10 BTDC) and 2) Check the fuel level through the site glass. 1/8" above center is too high.
Posted on: 2009/11/23 8:12
From mauritius
I have already adjust the fuel level and would like to know how to fine tune for the ignition timing on the a14 engine. Here am posting a photo of the fuel level.
jpg  fuel level.jpg (138.28 KB)
12606_4b0a4b94a0951.jpg 2164X1652 px
Posted on: 2009/11/23 8:45
From SE Melbourne
Wiki pretty much reiterates the workshop manual
http://datsun1200.com/modules/mediawi ... php?title=Ignition_Timing
Posted on: 2009/11/23 9:28
Mildman, Datsunless
From Perth WA AUS
Is your Anti-dieseling valve connected and working properly?
Posted on: 2009/11/23 10:14
Datsun 1200 2Dr sedan.
