Battery AMP Power for a1200 ?
From Sri Lanka
Hi Guys
What is the Battery power in AMP required for 1200 ?
Is it 50, 60 or 70 ?
thanks
regards
Sumith
Posted on: 2009/11/23 5:28
Re: Battery AMP Power for a1200 ?
20 amp-hour for 33-35 minutes is all that is required.
You can use a small tractor battery, or the smallest car battery.
In USA, they fitted large batteries, same size as V8 for some odd reason. These batteries were probably less than 300 Cold Cranking Amps.
Posted on: 2009/11/23 5:37
From Sri Lanka
Hi ddgonzal
Here we got NS 40-50-60-70 ranges a lot
So then NS40 or 50 will be quiet enough ?
thanks
regards
Sumith
Posted on: 2009/11/23 5:43
I'm sure it will be.
Here is my battery, and others are running even smaller battery:
Posted on: 2009/11/23 7:15
