PCD on 1200
From cold toast
hey guys just to double check 1200 ute has 4x114.3 pcd, right?
and what offset can and width can be safely, or just run with minor to no gaurd mods
thanks
Posted on: 2009/11/26 10:56
Re: PCD on 1200
From cold toast
http://www.auctiva.com/hostedimages/s ... 91122114&images=291122114,291122155,291122205,291122230,291122267,291122317,291122355,291122405,291122435,291122466,291122505,291122540,291122583,291122626,291122675,291122712&formats=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0&format=0
http://www.auctiva.com/hostedimages/s ... 91122712&images=291122114,291122155,291122205,291122230,291122267,291122317,291122355,291122405,291122435,291122466,291122505,291122540,291122583,291122626,291122675,291122712&formats=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0&format=0
they are the wheels im looking at
Posted on: 2009/11/26 11:02
Re: PCD on 1200
From brisbane
Hi mate
Yes 4 by 114.3mm is correct.
Not sure on offset as I am running different brakes, rear end etc but around positive 20 to 25 should be in the ballpark.
Matty
Posted on: 2009/11/26 11:11
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: PCD on 1200
From cold toast
okay thanks a bunch
anyone no about offset?
Posted on: 2009/11/26 11:13
Re: PCD on 1200
From Cape Town, South Africa
4 114mm also works, I'm pretty sure a lot of Toyota vehicles is 4 114mm.
Posted on: 2009/11/26 11:14
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Re: PCD on 1200
From cold toast
aw cool, is it easy to get them on?
Posted on: 2009/11/26 11:16
Re: PCD on 1200
Toyota rear-wheel drive wheels are also 114.3 PCD.
For Datsun, the original specification was imperial measurement: 4.5 inch bolt center. The metric equivalent is 114.3mm.
Posted on: 2009/11/26 22:10
Re: PCD on 1200
From cold toast
anyone no how much offset i can run?
Posted on: 2009/11/26 23:15
Re: PCD on 1200
How much offset you can run depends on the wheel width and the tire size.
The stock offset is +30 mm with 4" wide wheels. Most 5.5" wide wheels with appropriate offset will fit under the fenders of a Datsun 1200. Most 6-inch wide will not fit inside the gaurds, but theoretically (with the right offset) it is possible. Utes can fit wider wheels on the rear.
Tires: if you have 13" low profile you can run any amount of positive offset, like these 9-inch wide watanabes:
Posted on: 2009/11/26 23:26
Re: PCD on 1200
From cold toast
okay i think im following, the wheels im looking at are 6inch wide
Posted on: 2009/11/27 0:57
