Browsing this Thread:
1 Anonymous Users
Re: Race pistons, rods, cams, dual springs, retainers.... for A12/13/14/15. |
From Townsville, Qld
yeah there's nothing worse than having mooshy valve springs that aren't rated for the lift your cam
Posted on: 2009/12/3 2:54
can i use this cam on my stock engine i mean all stock internal ... is there any efect using this ( sry noob question )
Posted on: 2009/12/3 9:58
When your using a cam with more aggressive characteristics than a stock cam you should use stronger valvesprings (ideally mated to the maximum valve lift of the cam and maximum rpm you want to run) to aviod having the valves floating at higher RPMs. Valve float is one step away from bending the valves and possibly doing more damage to the rest of the motor. Pretty sure I'm on the right track with that.
Posted on: 2009/12/3 10:33
From St. Louis, MO USA
USED
Posted on: 2009/12/3 19:38
Edited by pjz on 2009/12/3 20:43:00 Edited by pjz on 2009/12/4 20:13:38
NEW set of MANLEY 39mm/33mm RACE VALVES, KEEPERS, LASH CAPS & GUIDES.
(4) new 39mm intake and (4) new 33mm exhaust, built with 7mm stems, plus (16) keepers, (8) lash caps and (8) valve guides. The keeper groove has not been cut, so your machine shop can set them up for you.
Custom valves cost about $800 usd. I will take $450 for everything above. [Do I need to post a picture?]
CHROME MOLY 3-PC PUSHRODS: $45 usd + $15 shipping worldwide.
(8 + 1 spare) chrome moly pushrods with 5.805" effective length. [Effective length is the overall length of the pushrod, minus the depth of the cup.] (8) chrome moly pushrods, 6.20" effective length. (8) chrome moly pushrods, 6.575" effective length.
Peter e-mail is best PeterZekert"at"Juno.com
Posted on: 2009/12/3 21:54
Edited by pjz on 2009/12/3 22:42:18 Edited by pjz on 2009/12/3 22:42:50 Edited by pjz on 2009/12/3 23:29:00
