Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: octane booster
perthute
Posted on: 2009/12/7 6:43
lol 91 ron in my silvia make it go ping ping no thanks and the cheaper fuel is made from #OOPS#
#12
Re: octane booster
1000Coupe
Posted on: 2009/12/7 6:57
sorry mcgee i didnt mean use 91 with boost. with boost 98 only, even though some modern factory engines are designed to use 91 with low boost 7psi or less, they are hi tech knock sensors and all.
#13
Re: octane booster
Reeves
Posted on: 2009/12/7 7:06
Try some mothballs in your tank .... """naphthalene"""
Works for me. LOL ![]()
#16
Re: octane booster
greendog
Posted on: 2009/12/7 10:58
no point unless u have good ignition i reckon.
#17
Re: octane booster
datski620
Posted on: 2009/12/7 11:06
i had to run octane booster in my old 620 as the compression is well over 11:1 and would ping on 98 but when i was running on 103 octane she ran beautifully....soon i will know how much power my engine puts out when the guy who got it gets it dyno tuned hehehe
#18
Re: octane booster
matty
Posted on: 2009/12/7 11:44
I run my cars on BP Ultimate. When tracking them I also add a bottle of Nulon Pro Strength Octane Booster.
Matty
#19
Re: octane booster
DATUTE1
Posted on: 2009/12/8 0:42
Does anyone use those valve buster additives with unleaded fuel. Or can a standard A14 run fine without it?
#20
Re: octane booster
1000Coupe
Posted on: 2009/12/8 0:57
I use moreys upper cylinder lubricant,
another variable is burning oil, that causes pinging on very hot days and under load because the oil pre-ignites easily, so u need to up the octane to stop it. mostly the compression is dropping on a tired motor burning oil so it doesnt happen, but if u have burning oil with good compression its a problem. You can view topic.
