Re: octane booster
From perth airport
lol 91 ron in my silvia make it go ping ping no thanks and the cheaper fuel is made from #OOPS#
Posted on: 2009/12/7 6:43
perth airport parking
Datsun 1200 ute A14
Re: octane booster
From Perth WA
sorry mcgee i didnt mean use 91 with boost. with boost 98 only, even though some modern factory engines are designed to use 91 with low boost 7psi or less, they are hi tech knock sensors and all.
Posted on: 2009/12/7 6:57
datsun 1000, Its not the size its how u use it.
Re: octane booster
From South Africa
Try some mothballs in your tank .... """naphthalene"""
Works for me. LOL
Posted on: 2009/12/7 7:06
Life's a bitch, so f...k it.
Re: octane booster
From Perth WA
that was proven to work on mythbusters
Posted on: 2009/12/7 7:40
Re: octane booster
From cold toast
what will they do?
Posted on: 2009/12/7 10:48
Re: octane booster
From south coast nsw
no point unless u have good ignition i reckon.
Posted on: 2009/12/7 10:58
Re: octane booster
From Albany, Perth Australia
i had to run octane booster in my old 620 as the compression is well over 11:1 and would ping on 98 but when i was running on 103 octane she ran beautifully....soon i will know how much power my engine puts out when the guy who got it gets it dyno tuned hehehe
Posted on: 2009/12/7 11:06
1200 Smerf Mobile
Re: octane booster
From brisbane
I run my cars on BP Ultimate. When tracking them I also add a bottle of Nulon Pro Strength Octane Booster.
Matty
Posted on: 2009/12/7 11:44
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: octane booster
From Nations Capital, Australia
Does anyone use those valve buster additives with unleaded fuel. Or can a standard A14 run fine without it?
Posted on: 2009/12/8 0:42
Re: octane booster
From Perth WA
I use moreys upper cylinder lubricant,
another variable is burning oil, that causes pinging on very hot days and under load because the oil pre-ignites easily, so u need to up the octane to stop it. mostly the compression is dropping on a tired motor burning oil so it doesnt happen, but if u have burning oil with good compression its a problem.
Posted on: 2009/12/8 0:57
« 1 (2)
