« 1 2 3 (4) 5 6 7 ... 54 »
Re: Leveys 2dr sedan v1.2
From Perth WA AUS
Ok, now just have to fit the filter covers then the main cover and its done.
Posted on: 2009/12/13 9:32
Datsun 1200 2Dr sedan.
From perth western australia
jealous much lol... ill let you make one for mine nige :P
Posted on: 2009/12/13 10:10
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
From Perth WA AUS
You can make your own Its not that hard, I will help of course.
Posted on: 2009/12/13 10:15
From Perth WA
luv that airbox, cold air pickup makes a big difference.
Posted on: 2009/12/13 10:43
datsun 1000, Its not the size its how u use it.
From Perth WA AUS
Thanks John, Its mainly to get over the pits. It is quite restricted air flow wise though, hopefully it will help quieten the induction noise and limit the power a bit ( it is supposed to be an A12!).
Posted on: 2009/12/13 11:18
yeah i know you will help lol someone has to... i am loving the piping ey will have to check it out soon enough
Posted on: 2009/12/13 13:35
1000 coupe aka kb10
Are you going to run a pre-filter on the cold air intake? Or just a bit of mesh or something? Is the box alloy? U should get someone to tig it up if it is..
Posted on: 2009/12/13 14:10
From Perth WA AUS
Yeah Bailz its alloy not going to worry about welding, airfilters are enclosed inside the box.
Posted on: 2009/12/14 12:37
From Mandurah, Western Australia
When I got the CA over the pits, I made up a restrictor plate for the exhaust out of 1.2mm mild steel and slipped it into the exhaust pipe at a flange point. It retricted power and noise dramatically.
Might be woth considering as its a easy mod and would help pass the engine off as a A12
Posted on: 2009/12/14 12:42
did you finish it today nige??
Posted on: 2009/12/14 12:46
1000 coupe aka kb10
