Re: Compression Ratio?
From South Africa
From experience, if you skim the block more than 1.5 or 2mm you need to load the head studs or bolts a few times before you do your finnal pass in the mill, reason being that it will make a slight buldge around all the head stud holes (besides oil hole) due to the slight change in loading area, also a good idea to add a tiny champher as the threads start to stop the top thread pulling up slightly.
I have seen people taking 4mm off between head and block, one must just remember to take into account what it does to the rocker angle, for most that run cut cams its actualy good because it makes it easier to get the perfect rocker ratio.
Posted on: 2009/12/14 6:45
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
Subject Poster Date
     Compression Ratio? LOWTECH 2009/12/9 9:04
       Re: Compression Ratio? jmac 2009/12/11 21:23
       Re: Compression Ratio? LOWTECH 2009/12/14 0:04
         Re: Compression Ratio? ddgonzal 2009/12/14 5:04
       Re: Compression Ratio? LOWTECH 2009/12/14 5:43
         Re: Compression Ratio? ddgonzal 2009/12/14 6:36
           Re: Compression Ratio? ROConnor 2009/12/14 6:45
       Re: Compression Ratio? Rezlo 2009/12/14 6:45
         Re: Compression Ratio? ddgonzal 2009/12/14 6:49
       Re: Compression Ratio? LOWTECH 2009/12/14 6:57
