Re: Adjustable strut tops where do you get them?
From South Africa
Problem with the S13 ones is that once youve made an adjustable top spring hat the suspension sits up a bit higher than it used to, not a problem for those with coil overs on the front, but for some running fixed lower purches this can be a problem Busy machining a new set of upper spring hat from scratch to try solve this.
Posted on: 2009/12/16 5:00
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
Subject Poster Date
     Adjustable strut tops where do you get them? boondy 2009/12/16 2:00
       Re: Adjustable strut tops where do you get them? old_school 2009/12/16 2:30
         hey Janice198896 2009/12/16 3:32
           Re: hey PIGDOG 2009/12/16 3:36
       Re: Adjustable strut tops where do you get them? Rezlo 2009/12/16 5:00
