« 1 (2) 3 »
Re: Help with bleeding brakes??
From Perth WA AUS
Yeah I know, just cant find it! frustrating.
Posted on: 2009/12/15 12:49
Datsun 1200 2Dr sedan.
From perth airport
gee i thought this was a joel thread :P
Posted on: 2009/12/15 22:00
perth airport parking
Datsun 1200 ute A14
From perth airport
so levey you bleed it and there good ? then fade off ? then there more air bubbles ?
Posted on: 2009/12/15 22:02
Datsun 1200 ute A14
From Melbourne AUS
are you using a booster?
a standard 1200 master cyl?
if not, some master cyls are designed to seal with the booster unit and if used directly on the firewall they just keep sucking in air to the system.
worth looking at. i swore many times before i worked this out.
Posted on: 2009/12/15 23:38
1973 B110 A12
From Perth WA AUS
Hmm, It did come with the correct setup to fit to the brake pedal so I assume its the right one.
Posted on: 2009/12/16 7:03
From Melbourne, Australia
the base of the nipple your undoing could be leaking?
we bought an air bleeder after much swearing and cursing and that works awesome (need a compressor and not sure how much it cost so potentially not being that helpfull )
Posted on: 2009/12/16 7:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Perth WA AUS
Thanks anyway, I stripped the master down and all seemed ok, checked all connections etc and put it back together, bled the brakes twice and now its a fair bit better. Only have to push the pedal twice to get some firmness in the pedal so getting there, still dont know what the problem was though!
Posted on: 2009/12/16 11:27
mine is still a little spongy too,mrs pumped pedal while i bled it. still not firm enough but better than a one man bleed kit i used by myself.
Posted on: 2009/12/16 11:35
From Perth WA AUS
Oh, thats what I'm using.
Posted on: 2009/12/16 11:49
could be the opperators, not the tools
Posted on: 2009/12/16 11:51
« 1 (2) 3 »
