Re: HUGE Brakes. Bit of a overkill??
bigger the better!
Posted on: 2009/12/18 5:49
From South Africa
Odd, with my stock weight B110, stock brakes (only change is later year champ calipers) and hot A15 ive never seen the need to upgrade the brakes, even in a 90min enduro she ran flat out with never even a hint of brake fade...
Posted on: 2009/12/18 6:42
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From Melbourne AUS
i dont see the need for massive brakes on a 1200. unless its a track car. i run the small s13 brakes which are more than enough for my ute.
Even my old stanza'a used to stop it well enough.
Posted on: 2009/12/18 6:57
1973 B110 A12
From Newcastle nsw
hmmmm, im still not sure what im going to do. I dont really plan on hittin the track often,and i wanna keep rims/tyres in the gaurds. My old sedan i had was fitted with 120y brakes, and it was fine. The offset of the rims i am not sure of, but they are 15x6 performance alloys, and fit nice on the rear,but not so nice up front. Might try findin some standard struts & do a coilover conversion to em. i also will have some 180sx brakes layin around shortly after i upgrade a mates 180 to 5 stud and big brakes. maybe that combo will fit better with the rims/tyres/gaurds. What ya reckon?
Posted on: 2009/12/18 10:52
From Newcastle nsw
anyone done a 180/silvia brake conversion??
Posted on: 2009/12/18 10:53
From Sydney, Australia
120y brakes == fine? Have you not driven a car with good brakes?
My Mum used to a have a 1200 coupe with a14 and 120y front brakes. At the same time I had the verada/commodore caliper conversion on my 1200 sedan, and driving her car made me feel REALLY unsafe.
120y calipers/rotors on a 1200 with any more than an a-series is dangerous, unless you are 18 with strong Jedi forces.
Posted on: 2009/12/18 21:19
From Christchurch NZ
I run 250mm S13 brakes on standard 1200 disc brake struts. They are awesome! The only thing that limits my stopping is my tyres. Plus they only increase the track width by the thickness of the disk hat.
PLus they'll fit inside 13" cheviot trident mags.
If you can be bothered registering, I did a write up on the conversion here
Also, big heavy brakes increase your unsprung weight.
Posted on: 2009/12/18 21:21
Forced Induction!
From Newcastle nsw
yeh might try doin what u have done there a14force. sound like the go. Dattodude, ive probrably driven as many cars with good brakes as u have had hot dinners, being that i drive on average 8-15 cars a day that seem to pull up pretty good.
Posted on: 2009/12/18 21:49
From Albury
Have to agree with A14force. S13 brakes have far more serious continual stopping power than people realise.
Big cars need big brakes, little cars need littler brakes. Look at most of the open wheelers over here they have 13"rims over their brakes,have bugger all cooling as the brakes are deep inside those huge wheels and stop them all day. I know they are lighter but they are stopping them from warp speed in a small distance. They would be working heaps harder than a hot road car ever would.
Plus most of you young pups just want to go fast,you just want to stop once at the end of it.
Cheers
bob
Posted on: 2009/12/18 22:24
From gold coast QLD.
Hey Dattoboy,i reckon your dilema is easy fixed,you say you are using Performance alloys.They fit the back but not the front....then go to a dealer and order two more new wheels for the front with the off set you require,Performance offer a variety of differant offsets for under $200 per wheel.Thats got to be cheaper than re building the front end and you have the best of both worlds.
Posted on: 2009/12/18 22:44
« 1 (2) 3 4 »
