Help me with Valve Adjusment..
From Selangor, Malaysia
Hi Guys,
What is the valve clearance/adjustment that i should go for if i've skimmed/milled the head surface 2mm off?
Can i go for 0.013 COLD or 0.014 HOT?
Is it still safe to do so?
Thanks.
Posted on: 2009/12/21 2:38
dying to learn A series..help me :)
Re: Help me with Valve Adjusment..
You must use the same clearance as before. Only if you fit a non-standard camshaft will the clearance change.
0.013 inch COLD is the standard valve clearance. The official clearance specified by Nissan is 0.014 inch HOT.
Posted on: 2009/12/21 3:15
Then 0.014HOT i'll go for..
Thanks dd
Posted on: 2009/12/21 3:21
