Re: HUGE Brakes. Bit of a overkill??
From Newcastle nsw
PIGDOG, you were right, hz or hx caliper is what they are, disc is still unknown at the moment.
Posted on: 2009/12/21 10:44
From Geelong, Vic
disc shouldnt be to hard to find a replacement...doesnt really matter what it is at the moment though
but all you need is its diameter, thickness and height(dist from the mounting face to the back of the disc) then hit up the dba cataloge and find a disc with the same specs
being that they are hz/hx calipers the struts would most likely be stanza or 200b struts
Posted on: 2009/12/22 1:46
« 1 2 3 (4)
