Re: old_school's CA Coupe
i will take a pic of mine at the moment, hahaha, trust me thats not as bad as mine :)
Posted on: 2009/12/29 12:42
From Mandurah, Western Australia
Have had no time to work on the diff but sourced a set of Hilux calipers for the front. $90 inc freight from east coast for a set.
No joy in WA. Only wreckers that would help were Tony's Auto Wreckers and they wanted $165 each.
Will grab a seal kit and re-build these an then work out what rotors to use on the Stanza strut.
Posted on: 2010/1/15 12:02
From mandurah
hey old_school your doing the same brake setup as me and you can use silvia rotors (CA) as they will fit in 13 inch wheels aswell with the toyota calipers
and if you want seals, pads and rotors let me know and ill help you out on the price :)
Posted on: 2010/1/15 13:19
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
hey old_school did you have to change the gear box, tunnel at all and if so did it make rego harder?
Posted on: 2010/1/18 4:36
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
estyre, the more stuff u modify the more stuff that has to pass engineering.
if its not modified, it must of met a standard :)
try to cut the least amount of stuff possible... i am tellin ya u can fit with n tunnel mods. you can massage it if your desperate or lazy :) just be persistant :)
Posted on: 2010/1/18 5:01
Bailz is right. I did not modify the tunnel appart from massaging it in places to clear the box. However the gearbox mount was done how the engineer wanted it done. I originally just bolted one to the floor plan and this was not acceptable. So you need to consult a engineer and ask how they want it done. I had to pull all the carpet out and weld a new cover over the old gear stick hole as well as he did not like the first one I put in and this, at the time was a pain in the butt.
I used the Corolla diff with the Stanza brakes to get the car rego as this diff was bolt in and required minimal mods. Hense now I am building the Skyline diff because if this was done initially this would have to be engineered. More headaches and money.
The engine is best if it is stock appart from a pod filter because they will pickup on all modifications. Because more hp effects the engineering on the vehicle.
The inspection centers in WA are on the ball with all this because a few were burnt badly for passing illegal vehicles. MH Diesel inspected my car and had it for 6 hrs on the hoist checking it over and that was after the engineering was completed.
Posted on: 2010/1/18 5:15
Not too shy to talk
From RoboCop
love the coupe!
Posted on: 2010/1/18 6:12
RoboCop
From Perth WA AUS
Yeah looks great.
Posted on: 2010/1/18 8:38
Datsun 1200 2Dr sedan.
From mandurah
ok cheers old_school i dont need to massage the tunnel at all in my coupe cos it has an auto tunnel but the mounts for the box were changed by the guy that owned it before darren
Posted on: 2010/2/1 4:50
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Its time to get stuck into this again, need it done before the show car season.
Pulled the diff out of storage today, next job is cut all the crap off it ready for shortening.
jpg  r31 diff.JPG (30.21 KB)
2484_4c43011e81535.jpg 448X336 px
Posted on: 2010/7/18 14:27
« 1 2 3 4 (5) 6 7 8 9 »
