« 1 (2) 3 4 5 ... 9 »
Re: DEDICATED CA18DE T THREAD
From Mandurah, Western Australia
The CA18 Gearstick boot as seen in the pix
P/No: 32862-V5001
(Suit S13, 1989, CA18DET)
$22.70 - RRP
A young guy at Mandurah Nissan sourced this for me. Apparantly Nissan can get most parts for a grey import, if they are paid for in advance. However he said that alot of dealerships will not get involved with grey imports as once you order something it cant be sent back. Also ring around as a Perth dealer (who was recomended as they source alot of import parts) wanted $69.00 for the same part.
jpg  boot.jpg (19.30 KB)
2484_4b3b3355354d5.jpg 400X300 px
Posted on: 2009/12/30 11:07
I am still having troubles withs afm. As soon as I plug it in the car revs up a tiny bit then dies.. I have codes for cas and afm fault on ecu
Posted on: 2009/12/30 13:35
Heres the Factory service manual for ca18det..
its about 27mb or something..
http://pdftown.com/Nissan-S13-CA18DET-Engine-Manual.html
Posted on: 2009/12/31 3:19
Air Flow Meters
Theres a test for them to see if they are faulty..
Using car bettery voltage 12V..
Put + onto pin B, put - onto Pin C.
Then put your multimeter red lead onto d and the black lead to - side of battery.
With no airflow you should see apprx 1V from Pin D to - side of battery.
Whilst holding the multimeter on pin d and - side, blow air through the AFM, the voltage should vary from 1V up to about 3V.. if it does, it works ;)
Posted on: 2009/12/31 3:27
From mandurah
hey bailz arent you an auto electrician
Posted on: 2009/12/31 3:43
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
i am a sparky, not an autospark, still learning some of the auto leccy stuff in spare time..i am industrial spraky, generators, powerstations etc etc
Posted on: 2009/12/31 3:47
also, you can get engine mounts off ebay if your not keen on getting the maddat ones.
i am pretty sure that the landrover V8 ones are more than suitable for this application, i have used them on mine and at less than 50 delivered to your door, you cant complain :)
i will get the link up soon.
Posted on: 2009/12/31 3:56
sounds like a good alternative and probably neater design.
Anyone know of crank pulley kits to remove air con and power steering?
eg. alloy crank pulley kits? or better to just machine the 2 others from
the ogirinal and have it rebalanced?
Posted on: 2009/12/31 4:10
u mean harmonic balancer? i just left mine on, saves alot of muckin around, fits fine. i just run alternator thats it...
Posted on: 2009/12/31 4:13
Posted on: 2009/12/31 4:21
